2001 Nissan Maxima PASSENGER POWER WINDOW STUCK OPEN
92,000 MILES • 6 CYL • FWD • AUTOMATIC
RUSSH
Is there a way to force the window closed when the motor has failed? The inside door panel is off and I have access to the motor, etc. I would like to get the window closed so I can drive it until I can get it to the shop.
Mar 30, 2008 at 6:55 AM
RACI47
  • 85 POSTS
yes but you will have to cut the cable that runs inside of the regulator because the motor will not let the window go up or down or because the cable in the regulator is mangled be prepared with self tapping screws to the regulator up and down sliding part UNDER the window to regulator mount and dont screw it into the glass
Apr 8, 2008 at 4:19 PM
