2001 Nissan Maxima Leaking Coolant
2001 NISSAN MAXIMA
152,000 MILES • 6 CYL • 2WD • AUTOMATIC
CLOWE30
I noticed today as I was driving that there was a slight stream of smoke coming from the front end of my car. When I got home, with car still running, I popped the hood and saw coolant leaking. I'm not sure if it is coming from the radiator. How can I tell where the leak is coming from? Is it possible that it is a cracked radiator?
Jul 29, 2009 at 12:09 PM
BUDDYCRAIGG
  • CAR REPAIR CONTRIBUTOR
  • 2,262 POSTS
to find the leak, you need to visually inspect it.
is it coming from somewhere on the engine or on the very front of the car,
also check the overflow tank
Jul 29, 2009 at 3:59 PM
CLOWE30
It is leaking from the very front of the car. The reservoir is still at the max line. I'm not sure what the overflow tank is. Is it the same as the reservoir? I'm crossing my fingers and praying that it's just a hose that needs to be replaced.
Jul 30, 2009 at 2:08 AM
