2001 Nissan Maxima High rpm
55,206 MILES • 6 CYL • FWD • AUTOMATIC
POYANG1019
i would like to know about the problem of my car, which is, has a High rpm of 3000.. when it's in park gear position? and it comes down in 1000-1500 in drive gear position..
My question is , what are the possibilities must be change and repair? thank you in advance..
May 2, 2008 at 10:32 AM
  • 75,988 POSTS
Too fast an idle speed. If an engine without computerized idle speed control is idling too fast and refuses to come down to a normal idle speed despite your best efforts to back off the carburetor idle speed screw or air bypass adjustment screw (fuel injection), air is getting past the throttle somewhere. Common leak paths include the carburetor and throttle body gaskets, carburetor insulator spacers, intake manifold gaskets, and of course, any of the engine's vacuum fittings, hoses and accessories. It is even possible that leaky O-rings around the fuel injectors are allowing air to leak past the seals. Another overlooked item can be a worn throttle shaft and a defective idle speed speed control motor/valve stuck in the extended (high idle speed) position/throttle position sensor.
May 2, 2008 at 10:58 AM
