2001 Nissan Maxima Fuel pressure ragulator valve
2001 NISSAN MAXIMA
84,000 MILES • 6 CYL • FWD • AUTOMATIC
BAUMSC
where is the fuel pressure regulator valve located at and how do i go about taking it out and replacing it.
Jul 11, 2008 at 2:37 PM
The fuel pressure regulator is located at the end of the fuel rail, near the top of the engine, next to the throttle body and right below where you see the two throttle cables. The regulator is held in place by two screws. It has two hoses connected to it - a vacuum hose on top, and a fuel return hose on the bottom. To remove it, you will need to first relieve the fuel pressure, then remove the air intake duct and resonator from the throttle body and air flow assembly.
Jul 11, 2008 at 10:55 PM
