2001 Nissan Maxima filter replacement
2001 NISSAN MAXIMA
134,000 MILES • 6 CYL • FWD • AUTOMATIC
CORRYS
I am getting ready to change the tranny filter on my maxima and after some research I have found out that its covered under a valve body, is this true should I still replace it, is it neccessary
Sep 13, 2008 at 7:53 AM
2CARPRO JACK
  • 11,533 POSTS
It is more of a screen than a filter.That trans has a drain plug, then you refill it.Use only Nissan trans fluid for your trans those transmissions are time bombs to begin with, the incorrect fluid will not do them any good. Be prepared for the price though it is considerably more than regular ATF
Sep 13, 2008 at 8:03 AM
