2001 Nissan Maxima blower motor speed
2001 NISSAN MAXIMA
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
ATDGLD
  • 19 POSTS
my ac/hrt blower switch will not control the blower motor properly--amplifier is new--blower motor is new--fuses ok
Jun 14, 2010 at 3:31 AM
2CARPRO JACK
  • 11,533 POSTS
By amplifier do you mean the actual controller in the dash? Is this an automatic system or manual and which model of Maxima do you have?GLE,GXE,SE?
Jun 15, 2010 at 12:48 AM
ATDGLD
  • 19 POSTS
MY NISSAN MAXIMA IS THE GLE--MANUAL AC CONTROLS---THE AMP/RESISTOR IS IN THE BLOWER CAGE THAT IS NOT THE PROBLEM--THE SWITCH ON THE DASH SEEMS TO BE THE CAUSE FOR THE BLOWER NOT WORKING CORRECTLY
Jun 15, 2010 at 5:28 AM
ATDGLD
  • 19 POSTS
WHO DO YOU GET THE BLOWER SWITCH OUT OF THE DASHBOARD
Jun 16, 2010 at 12:29 AM
2CARPRO JACK
  • 11,533 POSTS
Sorry for all the questions, the wiring is different for them all.Looks like the center bezel with the vents in it just pops off, then you have to remove the center console shifter bezel which just pops off as well.Once those 2 are removed you should be able to see the screws holding it in.
https://images.2carpros.com/forum/automotive_pictures/1639_nissan2_3.jpg
https://images.2carpros.com/forum/automotive_pictures/1639_nissan3_1.jpg
Jun 16, 2010 at 1:24 AM
