2001 Nissan Maxima ACCELERATION PROBLEMS
114,000 MILES • 6 CYL • FWD • MANUAL
BRNDN_STALLWORTH
I HAVE A 2001 NISSAN MAXIMA WHICH IS PERFORMING HORRIBLY. i TYPICALLY ONLY DRIVE THIS CAR IN THE SPRING AND SUMMER SO WHEN I FELT MY CLUTCH SLIPPING AT IN THE BEGINING OF THE FALL I DECIDED TO WAIT UNTIL SUMMER TO FIX IT. oNCE I FIXED MY CAR IN MAY IT WASNT PERFORMING THE SAME, THERE WAS SOME TYPE OF LAG AS THOUGH THERE WAS LESS PEP. i THOUGHT IT WAS BECAUSE I WENT FROM A RACING CLUTCH TO A STANDARD CLUTCH BUT THAT WASNT THE CASE. iT CONTINUED TO GET WORSE AND MY CHECK ENGINE LIGHT LED ME TO BELIEVE IT WAS MY SPARK PLUGS AND O2 SENSOR. nEITHER FIXED THE PROBLEM AND NOW THE CAR ISNT DRIVEABLE ON THE HIGHWAY CAUSE THERE IS NO POWER. I BARELY CAN DRIVE IT AROUND TOWN. mY GAS MILELAGE IS HORRIBLE AND IM AT ALOSE. i LIVE IN CT AND I DID LEAVE MY CAR OUTSIDE FOR 8 MONTHS BETWEEN FALL TO SUMMER I DONT KNOW IF THE ELEMENTS HAD SOMETHING TO DO WITH IT CAN YOU HELP PLEASE?
Dec 16, 2008 at 6:14 PM
  • 75,988 POSTS
Check the fuel pressure with a fuel pressure tester with and without the pressure regulator-is it within specs ? We start from here.
Dec 16, 2008 at 6:20 PM
