2001 Nissan Maxima ABS SLIP TCS Lights
MOMOF3SELLS
i have a 2001 nissan maxima, it has about 108000 miles on it. Recently my ABS, SLIP and TCS lights are on, nothing unusaul about the car running different. But i hear a noise under my car, can you help, what should i do?
Sep 20, 2007 at 12:10 AM
SQM
  • 6,383 POSTS
When the on-board diagnostics detects an issue with the vehicle braking/traction control system, it triggers those lights.
The ABS, SLIP and TCS lights are all likely due to the same issue.
The best course of action is to have the vehicle scanned for ABS codes. This can help with the diagnostics. As the issue could be a sensor, bad wiring or module.
Here is a helpful video:
https://youtu.be/rTtAnsOlZU4
Oct 26, 2021 at 12:48 PM
Suggested Repair
Have the vehicle scanned for ABS codes. The ABS, SLIP, and TCS lights are likely from the same braking or traction-control fault, which could be a sensor, wiring, or module.
Conversation Summary
The owner of a 2001 Nissan Maxima with about 108,000 miles reports that the ABS, SLIP, and TCS lights are on and hears a noise under the car, though the car otherwise runs normally. The expert explains that the onboard diagnostics detected a braking or traction-control issue and that all three lights are likely related. The recommended next step is an ABS code scan to help determine whether the cause is a sensor, bad wiring, or a module.
