2000 Nissan Maxima What is going on?
106,000 MILES • 6 CYL • 2WD • MANUAL
LEVI EVENSON
When I accelerate, if i push on the peddal to hard or quickly, my RPM's jump up to 3000, 4000 or 4500 and my car barley accelerates. So I let off the gas and gradually increase speed. It does this in every gear. Once this problem started I took it in and the mechanic said it was the clutch slipping. He put a brand new clutch in and replaced some seels that were leaking. I got my car back today and drove around the block, 30mph and it was fine. Then I took it up to 55mph and the problem started again. And now it does it at any speed..... again. Im loseing my mind, what could it be?
Apr 14, 2010 at 11:11 AM
  • 75,988 POSTS
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Apr 14, 2010 at 8:25 PM
