2000 Nissan Maxima turn signal & hazard lights
2000 NISSAN MAXIMA
TEETEE_3362
Electrical problem
2000 Nissan Maxima 6 cyl Front Wheel Drive Automatic
i replaced my turn signal flasher an my turn signal or hazard lights still is not working what should i do
Aug 12, 2010 at 11:13 PM
BLUELIGHTNIN6
  • 16,542 POSTS
if the fuses are good and the combo flasher is good then the issue will most likely be a faulty turn signal switch, the hazard's circuit runs through the turn signal switch as well.
Aug 12, 2010 at 11:56 PM
