2000 Nissan Maxima rough idle
93,000 MILES • 6 CYL • 2WD • AUTOMATIC
SAAILER
  • 20 POSTS
Thank you for your answer concerning disconect batt. b-4 replacing mass air flow sen.
I'm fixing daughter-in-laws nissan so she can get on the road. just got maf sensor. If you could tell me one more thing I will throw a few your way.
I want to make sure vacumn line from intake to egr valve is not plugged. However I can't find the the egr valve I know it's in the exhaust man. SOMEWHERE. Can you help me locate it....saailer
Aug 1, 2008 at 8:11 AM
  • 75,988 POSTS
Its on the driver side, under the intake , on the side of the engine block well hidden, there is apparatus with block plastic body round 2" in diameter with a alumium bottom and two hoses coming out of it mounted with 2 bolts .
Aug 1, 2008 at 10:39 AM
