2000 Nissan Maxima radiator repair
20,000 MILES • 6 CYL • FWD • AUTOMATIC
B0449888
I am replacing the radiator & fans. Do you have step by step instructions?
Also, should I replace the water pump at this time? It leaks slightly.
May 3, 2010 at 6:54 AM
BLUELIGHTNIN6
  • 16,542 POSTS
if the water pump is weeping coolant then it's definitely on its way out. Drain the cooling system. Remove or disconnect the following: Negative battery cable Coolant reservoir tank and bracket Upper mounting bracket Upper radiator hose Oil cooler lines, if equipped Lower radiator hose Cooling fan and condenser fan Fan motors and shields Radiator To install: 1.Install or connect the following: Radiator Fan motors and shields Cooling and condenser fans and torque the bolts to 44 inch lbs. (5 Nm) Lower radiator hose Oil cooler lines, if equipped Upper radiator hose Upper mounting bracket Coolant reservoir tank and bracket and torque the bolt to 44 inch lbs. (5 Nm) Negative battery cable Fill the cooling system to the proper level. Start the vehicle, check for leaks and repair if necessary.
https://images.2carpros.com/forum/automotive_pictures/261618_0996b43f802059bc_1.jpg
May 3, 2010 at 7:45 AM
