2000 Nissan Maxima New Muffler Assembly
100,000 MILES • 6 CYL • FWD • AUTOMATIC
DORANMICHIGAN
  • 5 POSTS
My muffler had to be replaced due to a bracket hanger that broke off from the Exhaust System Hanger. Instead of welding a new bracket hanger I had to buy a new muffler assembly.
My question is, the person who installed the assembly said the part was not the correct pipe. He also said it would be alright. Should I be worried about this?
The picture uploaded shows the type of part I had installed, not intending this is the correct part installed.[img:5443211ee0]http://www.2carpros.com/forum/automotive_pictures/89398_exhaust_2.jpg[/img:5443211ee0]
Dec 8, 2008 at 8:19 PM
MMPRINCE4000
  • 8,548 POSTS
If it is not leaking and fits, I would not be concerned, although I would have probably welded a new hanger on.
If you notice any performance loss, or driveability problems, then I would look at getting the right part.
I did not see a picture?
Dec 9, 2008 at 12:46 AM
DORANMICHIGAN
  • 5 POSTS
Does the configuration of the muffler, if it is wrong, degrade the cars performance?
I do have a hum noise, not normal, when accelerating.
Dec 16, 2008 at 8:48 PM
MMPRINCE4000
  • 8,548 POSTS
Unless the muffler is way too small, I would not expect any loss of performance. Mufflers have a flow, that is, an "in" and an "out", so unless it was installed backwards, I would not be concerned.
You can have a backpressure test performed if you think it has lost some power.
The hum could be a vibration in the exhaust, so I would make sure the hangers are in the proper places, so the exhaust is not rubbing against anything.
Dec 24, 2008 at 4:47 AM
