Probably misthreaded the drain plug. This is common mistake. If it was misthreaded then it probably backed out and then your oil drained out. Either that or maybe your filter was not tightened properly, but they do not need to be very tight so I would lean more towards the drain plug.
Thanks for using 2CarPros. Com!
SPONSORED LINKS
Thursday, February 26th, 2009 AT 8:26 PM
