2000 Nissan Maxima keyless remote
2000 NISSAN MAXIMA
118,000 MILES • 6 CYL • FWD • AUTOMATIC
AL MENDOZA
The keyless remote won't unlock the doors, It will lock the doors and open truck also the panic button doesn't work either
Apr 3, 2010 at 7:25 AM
CMDRDATATX
  • 54 POSTS
Have you tried replacing the battery? If that didn't help, open the remote, remove the circuit board and separate rubber button sheet from the circuit board. Using a q-tip clean the contact pads on the circuit board and the rubber inner contact (black dots). I is safe to use plain water to moisten the q-tip. Make sure it is dry before re-assembly.
Apr 26, 2010 at 9:33 PM
