2000 Nissan Maxima Intermittent Ignition Error
125,000 MILES • 6 CYL • 2WD • AUTOMATIC
KYLEKILL
I have a service code for the ignition error in #1 that is an intermittent problem. I have tried swithing plugs and coils around but it continues to error on #1. Also only has the problem maybe once out of a dozen starts where it will idle rough. Occasionally if you turn back off wait a few seconds and restart it is gone again. Might this be a connection problem in a harness or is computer going bad?
Jan 10, 2009 at 4:53 AM
2CARPRO JACK
  • 11,533 POSTS
Might be a problem with the injector.I had a Ford F-150 that kept spitting out ignition codes and it turned out to be a bad injector. You can try measuring the resistance across them all with a meter and comparing #1 to the rest
Jan 10, 2009 at 8:45 AM
