2000 Nissan Maxima Humming Sound when turning steering whee
RAYVICTORY06
2000 Nissan Maxima 6 cyl Front Wheel Drive
i HAVE 217k MILES ON the car. It makes a humming noise when I turn the steering wheel to the left or right. Sometimes I smell a faint burning odor when I left the hood to check out the problem. What's wrong. Other than this the car drives great.
Jan 18, 2009 at 12:25 AM
KHLOW2008
  • 41,812 POSTS
Hi rayvictory06,
Thank you for the donation.
When humming noise is present, it could be a failing pump, low fluid level or a bad pressure valve/hose.
As to the burning oil smell, it could be oil leakages that is getting onto the exhaust.
A visual inspection and test would be required to isolate the source.
Jan 18, 2009 at 1:56 AM
