2000 Nissan Maxima how to determine or fine which ignition
121,000 MILES • 6 CYL • 2WD • AUTOMATIC
THESOHN
I had a "check engin" light displayed on my dashboard. P1320 was displayed with a statement "engin misfire" using computer. Website I researched states that ignition coil be most likely the reason. Since I plan to replace all six spark plugs, I also like to replace the bad ignition coil. Also I like to know the location of the ignition coil among six.
Thanks,
Jan 8, 2009 at 10:49 AM
YASGER
  • 83 POSTS
[quote:45ec671382="thesohn"]Engine Mechanical problem
2000 Nissan Maxima 6 cyl Two Wheel Drive Automatic 121000 miles
Thanks,[/quote:45ec671382]
i am surprised it does not say which cylinder is not firing o well. Ok. take the wire connection that is connected to the coil and disconnect it. if it misses a beat then you know it a good coil... if not then you have found the bad coil...
Jan 18, 2009 at 3:43 PM
