fuel pressure
2000 NISSAN MAXIMA
MDG78745
What is the fuel pressure suppose to read?
Feb 21, 2010 at 2:14 AM
Fuel Pressure
With Regulator Vacuum Hose Connected (34 psi)
With Regulator Vacuum Hose Disconnected (43 psi)
Feb 21, 2010 at 8:33 PM
JOE1953
  • 806 POSTS
i am about to check the fuel pressure, but can't located the schrader valve.
Dec 13, 2019 at 10:20 AM (Merged)
there is no schrader valve. you need to open the line at the fuel filter and use the correct adapters.
JOE1953
  • 806 POSTS
Thanks For Answer my Questions.
you still have issues??
did you do a compression test???
i see you have no noid, but is there 12 volt power to one side of the injector???
have been watching your postings and responses.
JOE1953
  • 806 POSTS
do you mean a compression test on the cylinder or fuel pump? i use a noid light on the injector to check for pulse, the light didn't blink, i check for volt there is 12 volt.
compression in all the cylinders.
With no noid, the computer grounds the injectors based on the input from the crank sensor. you did get a response to that and did you replace it??
JOE1953
  • 806 POSTS
no i haven't check the compression in all the cylinders neither replace the crank sensor yet.
let us know
JOE1953
  • 806 POSTS
there is 12 volt power to one side of the injector but when i check the other side of the injector for pulse my test light do not blink.
you already know this from your previous post. you need to check the crank sensor.
JOE1953
  • 806 POSTS
i been trying to located the crank sensor haven't located it yet.
JOE1953
  • 806 POSTS
i replace a new crank sensor at the front of the engine under the crankshaft pulley but the engine still want start and there is no pulse at fuel injector connected.
