2000 Nissan Maxima cutting out
94,000 MILES • 6 CYL • FWD • AUTOMATIC
BRIAN34
engine is cutting out in heavy traffic when i'm feathering the gas pedal. like a bucking when you jack rabbit a standard. accelerating slowly 1st and 2nd gear with a steady press of the gas pedal causes it to cut out or buck, but when I'm heavy on the gas it accelerates smoothly. I have recently replaced fuel pump, tps, plugs and maf sensor. coil packs were done 30000 miles ago. corrected some problems but this one is driving me nuts. thank you
Mar 19, 2008 at 2:38 AM
RACI47
  • 85 POSTS
change the throttle position sensor
Apr 9, 2008 at 5:56 AM
