2000 Nissan Maxima code PO171 lest bank to lean
120,000 MILES • 6 CYL • FWD • AUTOMATIC
STEVIS
  • 28 POSTS
This car has what I would disccribe as a ignition ping when enging is at operating temp under acelleration or when engine is under a load. The code is po171 for 2 lean on bank 1. Any sugestions. Thanks Steve.
Sep 13, 2010 at 3:53 PM
  • 75,988 POSTS
Hi Stevis, Welcome to 2carpros and TY for the donation
Pinging could be caused bu an engine overheating, knock sensor not retarding the ignition timing and an EGR valve not opening and increasing the combustion chamber temperature
P0171
Lean fuel condition could be caused by one of the following below:
1.Vacuum leaks
2.EGR and PCV valve.
3.Low fuel pressure.
4.Dirty fuel injectors.
5.Mass Air Flow Sensor.
6.Oxygen sensor
Sep 13, 2010 at 5:33 PM
