2000 Nissan Maxima c-clip missing
2000 NISSAN MAXIMA
140,000 MILES • 6 CYL • FWD • AUTOMATIC
SCOUT118
where is the reverse senor switch? I read on another forum that if the c-clip from the drive axle stays inside the housing that you might get lucky and retrieve it thru the rev. sensor location. any true to that?
Thanks in advance
Kevin
Oct 27, 2009 at 5:15 AM
BMRFIXIT
  • 19,053 POSTS
You stating that you have an automatic tranny ? reverse switch is part of the neutral safety switch , but in case you have M/T then the reverse switch located on the right side transaxle case on M/T tranny you can remove speedometer pinoin to get to the inside (right side top of axle)
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_582.jpg
Oct 27, 2009 at 11:11 PM
SCOUT118
Yes it is an automatic. Where is the neutral safety switch located and do you think I can retrieve the clip thru the hole?
Thanks
Kevin
Oct 28, 2009 at 6:21 AM
BMRFIXIT
  • 19,053 POSTS
Neutral safety switch is located at the tranny under the shifter cable and no access point to the tranny under it
I had set you a picture of it
what about the speedometer pinion
over the right axle
Oct 28, 2009 at 11:48 AM
