2000 Nissan Maxima 4 trouble codes
R-O-N
Engine problem
2000 Nissan Maxima 6 cyl Manual trans 80000 miles
P0139 fuel air metering
P0138 fuel air metering
P1320 ignition signal primary
P0302 ignition system or misfire
Please tell me what I have to replace to correct this problem. Thank you so much.
Jan 16, 2008 at 1:26 AM
2CARPRO JACK
  • 11,533 POSTS
P0138,P0139 both refer to the right rear oxygen sensor. repalce sensor
P0302 is a cyl #2 misfire- could be bad coil or plug or injector.
P1320- Ignition signal interruption during crank/running- possible causes are- circuit open or shorted, defective power transistor(integrated with coil), defective condensor,defective crank sensor (CKP) , or CKP circuit open or shorted
Jan 16, 2008 at 7:09 AM
LOSTINMARS
  • 222 POSTS
if you got an individual cyl # (p0302) to go with p1320 consider yourself one lucky person. typically when p1320 sets it comes with a p0300, random misfire, code. nissan recommends replacing all 6 ignition coils with updated ones. since yours gave you the p0302 i might be inclined to try just the coil for that cylinder. i would highly suggest putting new plugs in as well.
Jan 23, 2008 at 3:38 PM
