2000 Maxima Starter
2000MAX
I am trying to replace the starter but cannot remove the lower bolt. Any suggestions?
Jun 1, 2007 at 7:09 PM
DATSUNRAISED
  • 37 POSTS
Is the bolt not very accessible, or is there just not enough elbow grease available? If it's just stuck, I have found Pb Blaster to work quite well on stuck bolts. I had a froze strut bolt from an exhaust leak that it did the trick on.
Jun 2, 2007 at 3:38 AM
2000MAX
Would you mind explaining more about the PB blaster?
Thank you,
Jun 2, 2007 at 4:22 AM
DATSUNRAISED
  • 37 POSTS
Pb blaster is a penetrating catalyst that can seep into places most other "loosening" products; like WD-40, cannot. It also works well to lubricate metal/metal surfaces.
Jun 2, 2007 at 5:23 PM
2000MAX
Thank you very much!!!
Jun 2, 2007 at 6:08 PM
