1999 Nissan Maxima Engine turns over but seems to not be fi
57,000 MILES • 6 CYL • FWD • AUTOMATIC
DAC1
Battery went dead, we jumped the car off and it ran fine. several days later batery had died again. Charge battery overnight ; engine turn over cranked went dead. Now it will not start and engine turns over fine;have confirmed that timing belt is in tact and operating. could this be the control module.
Jun 8, 2010 at 2:48 PM
  • 75,988 POSTS
Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jun 8, 2010 at 3:25 PM
