If you replaced the ignition parts (Coil and plugs) but it still misses it is probably the injectors. Pull the plugs on the cylinders that are missing and compare them to the ones that arent to see if there is any color difference. May even want to do a compression test first, just to be sure they are at the same compression as the rest of the engine
SPONSORED LINKS
Thursday, April 22nd, 2010 AT 11:21 PM
