1999 Nissan Maxima Altenator
BULLDAWG512
Electrical problem
1999 Nissan Maxima 6 cyl Front Wheel Drive Automatic
Need help getting started. Not to sure where to start. Coolant hose on top of alt. and not much room underneath.
Aug 30, 2009 at 12:43 AM
BMRFIXIT
  • 19,053 POSTS
Here is the factory information for removal and installation.
Removal and Installation
REMOVAL
1. Remove engine undercover RH.
2. Remove side inspection cover RH.
3. Loosen belt idler pulley.
4. Remove drive belt.
5. Remove A/C compressor mounting bolts (four).
6. Slide A/C compressor forward.
7. Disconnect alternator harness connector.
8. Remove alternator upper bolt and lower bolt
INSTALLATION
To install, reverse the removal procedure
Aug 30, 2009 at 1:17 AM
