1999 Nissan Maxima 1999 maxima chokes
TALLS
Engine problem
1999 Nissan Maxima 6 cyl Wheel Drive Type unknown Automatic 71,000 miles
My maxima takes couple seconds to start. when it starts the car feels like it's choking for gas ( it vibrates but not to bad ). when am speeeding i do not feel it but when i slow down or comes to a stop feels like the car wants to cut off ....
I got the car service too day , same thing happens ... Alot of people tells me a gas treatment should do the trick !!!!
Can you guys tells me what the problem is thank you !!!
Jan 6, 2008 at 10:47 AM
BMRFIXIT
  • 19,053 POSTS
[quote:80327a01c6="talls"]Engine problem
Can you guys tells me what the problem is thank you !!![/quote:80327a01c6]
Gas treatment and or fuel injector cleaner it will help some what
but also check tune up and the coils
do you get check engine light on
if so get the codes
Jan 6, 2008 at 11:01 AM
TALLS
[quote:8eab4a6999="BMRFIXIT"][quote:8eab4a6999="talls"]Engine problem
Can you guys tells me what the problem is thank you !!![/quote:8eab4a6999]
if so get the codes[/quote:8eab4a6999]
No the check engine light dnt come on , can i use Gas treatment and the fuel injector cleaner at the same time.
Jan 6, 2008 at 11:20 AM
BMRFIXIT
  • 19,053 POSTS
[quote:7c47460950="talls"][quote:7c47460950="BMRFIXIT"][quote:7c47460950="talls"]Engine problem
Can you guys tells me what the problem is thank you !!![/quote:7c47460950]
if so get the codes[/quote:7c47460950]
No the check engine light dnt come on , can i use Gas treatment and the fuel injector cleaner at the same time.[/quote:7c47460950]
it will be OK but don’t over do it
I would recommend using fuel injector cleaner
every other fill up or so
but you can use the gas treatment or what we call dry gas with no prob.
Jan 6, 2008 at 11:30 AM
