1998 Nissan Maxima Timing belt
120,000 MILES • 6 CYL • FWD • AUTOMATIC
DSTARK
The Nissan dealer I went to said that it would change my timing belt, and while they had it down, would also change the oil pump. This would cost me about $600.00. Does this sound like to much money? Do I really need to change the oil pump too?
Jan 4, 2008 at 11:37 AM
FISHERMAN
  • 937 POSTS
[quote:ff05a9d542="dstark"]Engine problem
1998 Nissan Maxima 6 cyl Front Wheel Drive Automatic 120000 miles
The Nissan dealer I went to said that it would change my timing belt, and while they had it down, would also change the oil pump. This would cost me about $600.00. Does this sound like to much money? Do I really need to change the oil pump too?[/quote:ff05a9d542]
Hello !!
Well Once you replace the timing belt its recommendable to replace all the oil seals the tensioner and the WATER PUMP....
the oil pump they said?
well ask them why !
It is damage?
Once you drive your car into a dealer they start making money and looking the way to make more..
I would recommend you to get a quote on a good shop and then compare the prices... you know, most of the people think that the dealer mechanics are always right and... that its not true!
we`re mechanics and some of us we used to work on a dealer and we know for a fact that the dealer charges a lot more money than a good reputable shop, on the same exact job.
also be sure that the part that they are replacing it need to be replaced !!
good Luck!
Jan 4, 2008 at 12:05 PM
