1998 Nissan Maxima temperature gage rises and falls
143,000 MILES • 4 CYL • 4WD • AUTOMATIC
K3BRIMSTONES
This car is a salvage title and was sitting at the buyers parkway for a while. The car runs smooth and fine. But from the second day after I bought it, the temperature gage rises and falls along with the acceleration. No oil/coolant leaks can be seen and I had thermostat changed today but it did no good. One mechanic said the engine is bad and needs to be replaced. I don't want to believe that. Please help and thank you for your time.
Nov 3, 2008 at 5:25 PM
ZACKMAN
  • 4,202 POSTS
Try replacing your temp sending unit. It could be just that.
To refute what the technician says about the engine being bad, perform a compression test on all cylinders. If they are within less than 20% difference, the engine is good.
Nov 6, 2008 at 12:59 PM
