1998 Nissan Maxima Irratic shifting
1998 NISSAN MAXIMA
NTOMASSETTI0530
Transmission problem
1998 Nissan Maxima 6 cyl Front Wheel Drive Automatic 175k miles
Transmission will shift fine in manual 1,2, drive. While in drive it will shift from first to second pretty quick, but after shifting wont engage, just rev. Is there any vacuum lines or modulators anything of that sort that may be causing the problem? Please help, don't want to replace trans. Thank you.
May 4, 2009 at 5:11 PM
DAVID MCADAM
Check transmission fluid level. Have you ever had the fluid changed? It should be cherry red, old burnt fluid is brown or black. Level is checked with the engine running and the selector in park or neutral.
May 11, 2009 at 3:31 PM
