1998 Nissan Maxima engine code
1998 NISSAN MAXIMA
130,000 MILES • 6 CYL • FWD • AUTOMATIC
CARJOH3657
What is the engine code P1320,and P0325 for my car are?
Dec 15, 2008 at 5:56 AM
ZACKMAN
  • 4,202 POSTS
P1320 Ignition Signal Ignition/Distributor Engine Speed Input Circuit Malfunction
Check wiring to your crankshaft position sensor. Make sure no frayed wires. Be prepared to have to replace the sensor, if necessary.
P0325 Knock Sensor 1 Circuit Malfunction (Bank I or Single Sensor)
Again, check wiring to the knock sensor. And you may have to replace the sensor, if necessary.
Dec 15, 2008 at 12:19 PM
