1998 Nissan Maxima cruise control
1998 NISSAN MAXIMA
PEEPERSMO
Electrical problem
1998 Nissan Maxima 6 cyl Front Wheel Drive Automatic 69.000 miles
Whenever I try to set the cruising speed the green light flashes and it won't engage. What could be wrong?
May 16, 2010 at 5:21 PM
BLUELIGHTNIN6
  • CAR REPAIR CONTRIBUTOR
  • 16,542 POSTS
hello and thanks for donating
unfortunately there are many switches that can fail and cause the CC to fail. the first place to start diagnostics is checking the brake light switch. this is a simple check, just have a helper look and see if your brake lights are working properly. if this is OK, check the steering switch. again this is easy also, just attemp to sound the horn, if it works then the switch is most likely good. does the transmission shift OK and is the speedometer working properly?
May 21, 2010 at 11:23 PM
