1997 Nissan Maxima Warning Lights
330,450 MILES • 6 CYL • FWD • MANUAL
CRIMSONDEVIL
My brake light and alternator (battery) lights will come on occasionally. They do not stay on consistently and the battery does not appear to drain. I had alternator and battery replaced last year.
Jan 11, 2009 at 6:06 AM
2CARPRO JACK
  • 11,533 POSTS
Most imports thebrake light comes on with the charge light when voltaeg is low. First start basic and be sure all battery connections are clean and tight. You may have a bad connection somewhere that is causing an intermittent problem.Next, when it comes on, you need to be able to read the voltage at the battery and alt wires(big wire) to see what it is really putting out
Jan 11, 2009 at 7:41 AM
