1997 Nissan Maxima Smog test codes
124,517 MILES • 6 CYL • FWD • AUTOMATIC
JARRETT88
My vehicle failed the functional test part of the smog test everything else passed. What do the fault codes P0110 and P0600 mean and what is the solution to the problem?
Mar 6, 2010 at 10:34 AM
LEGITIMATE007
  • 5,121 POSTS
po110 intake air temp sensor circuit malfunction. po600 dalta link connector failure. change the IAT, located on or near the air filter housing. and the connector for the scan tool, is faulty and needs to be repaired, but do the other one first. then rescan, the second code may not even come up or may be a false code, because I dont see how you can extract the first code and then it says it cant communicate.
Mar 6, 2010 at 12:06 PM
