1997 Nissan Maxima Power windows and locks
185,000 MILES • 6 CYL • FWD • AUTOMATIC
RWHIPLA
I had an alarm installed on my car that went bad. I took it our and now the driverside window and lock motor will not work. All other locks and windows work just fine. I have replace the switch and the window regulator to get nowhere. I can here the relay in the switch activating when the button is pressed. I am now at a lose as to what to look at next. HELP!!!!
Apr 3, 2008 at 4:25 AM
RACI47
  • 85 POSTS
if you have power going to the switch did you check to see if you have power going to the motor?
Apr 8, 2008 at 3:59 PM
RWHIPLA
There is no power coming out of the switch for anything power in the door. Nothing to the window motor nor to the door lock actuator. The switch works for all other doors though.
Apr 17, 2008 at 4:40 AM
