1997 Nissan Maxima oil pan gaskets
155,000 MILES • 6 CYL • 2WD • AUTOMATIC
HARRY ALLEN
My car is leaking oil really bad and I need to have the gaskets replaced. How long will this take and what is the approximate cost?
Thank You
Jun 29, 2008 at 3:25 PM
KHLOW2008
  • 41,812 POSTS
Hi Harry Allen,
Sorry I am unable to provide any costing but how sure are you it is the oil pan gasket?
Usually oil seals or the oil pressure switch tends to leak more than the gasket and if I am not mistaken, you engine has liquid gaskets which seldom leaks.
Jul 5, 2008 at 7:03 PM
HARRY ALLEN
Thank you for answering. I took my car to a second mechanic and found out that the timing chain gasket was leaking along wtih the upper gasket. I had the oil pan and upper gaskets replaced by the first mechanic who used the wrong sealent so the new mechanic replaced the gaskets on all the parts and I no longer have a leak. He charged me $658 for parts and labor which was not bad.
Thanks again.
Jul 6, 2008 at 1:57 PM
