1997 Nissan Maxima 4 cyl Two Wheel Drive Automatic high miles
i have a gas leak and I was on my to the shop to fix this problem but now my car won't start. It will turn over like it trying to start but nothing?
Friday, January 9th, 2009 AT 11:06 AM
BOYLEAL
MEMBER
Well I would start buy checking to make sure your intake is not clogged and that the air is getting threw fine. If the airway is clear, find out if you have fuel pressure. Get a fuel gauge from napa auto parts. Should be around 40 psi when you initially start the car and then 20 psi at idle. If you have 0 psi all the time then your fuel line is not delivering the fuel to your injectors. That is problem number one. Troubleshoot this and if you have fuel pressure then check the spark plugs and wires.
