1997 Nissan Maxima HELP
BROKENROSE1031
  • 1997 NISSAN MAXIMA
  • V8
  • 178,000 MILES
I ran out of gas, I put gas in about half of a quarter of a tank, it starts up but it seems like once it gets on it can't keep itself going, im not sure what I should do
Thursday, September 18th, 2008 AT 3:57 PM
BLACKOP555
  • 10,371 POSTS
Running out of gas is a good way to destory a fuel pump, I would like you to check the fuel pressure and get back to me
could also be dirt and garbage that got sucked off the bottom of the tank into the fuel system when the gas got low.
Thursday, September 18th, 2008 AT 6:26 PM
BROKENROSE1031
How do I check fuel pressure
Friday, September 19th, 2008 AT 1:20 PM
BROKENROSE1031
Also someone listened to the fuel pump and said the motor wasn't running
Friday, September 19th, 2008 AT 4:23 PM
BLACKOP555
  • 10,371 POSTS
To test fuel pressure you will need to attatch a fuel pressure test guage to the fuel port and then you have to wire the pump on constantly with scantool. And then run it and check and compare with specification.
Saturday, September 20th, 2008 AT 8:38 AM
Related General Content
