1997 Nissan Maxima CAR PROMBLEM
185,000 MILES • 6 CYL • 2WD • MANUAL
WONGKID07
  • 11 POSTS
My Maxima is hard to shift into any gears when the engine is on.When the engine is off you can change gears easily.there are no leaks and i just bleeded it and topped off some fluids.there is a noise when you are trying to put it in1st gear.runs fine once it is in gear.so why is it hard to change gears
Jun 13, 2008 at 10:43 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:e9cb4ba8f0="wongkid07"]Transmission problem
1997 Nissan Maxima 6 cyl Two Wheel Drive Manual 185000 miles
My Maxima is hard to shift into any gears when the engine is on.When the engine is off you can change gears easily.there are no leaks and i just bleeded it and topped off some fluids.there is a noise when you are trying to put it in1st gear.runs fine once it is in gear.so why is it hard to change gears[/quote:e9cb4ba8f0]
Has the Clutch ever been changed? If not my guess is the clutch has done it job and time for replacement.
Jun 13, 2008 at 1:09 PM
