Hi tophat and welcome to 2carpros
You said its getting fuel-how about spark do you have it-If not do below and tell me what's going on-
Disconnect a sparkplug wire or 2 and ground it to the engine and have helper crank engine over-do you have spark if no snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it.
Monday, October 27th, 2008 AT 3:32 AM
