1996 Nissan Maxima Smog check
289,000 MILES • 6 CYL • 2WD • MANUAL
JLDUENES
Took my car in for a smog check but the smog check
computer could not detect any reading from the car when car was plugged into smog cimputer. Is there a fuse that controls plug. Cruise control is also out. I worked on the radio (not working) and might have cased a short. What fuse on the 96 Maxima controls the Smog computer to have no read out on the car?
Car is running fine and no light on dash.
Oct 6, 2008 at 5:03 AM
BMRFIXIT
  • 19,053 POSTS
Use a test light and check fuses (all fuses )
that would be my 1st step
since you worked on the radio before
check also if the cigarette lighter working if not then its a fuses
www.2carpros.com/video.htm
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 6, 2008 at 11:37 PM
