1996 Nissan Maxima Rack n Pinion
1996 NISSAN MAXIMA
182,662 MILES • 6 CYL • 2WD • AUTOMATIC
LATINBOY909
  • 15 POSTS
Hey guys I want to know if the rack n pinion is the reason of making a noise when i stop at an intersection. It makes a noise like its rubbing with something or scratching. Also the control arm bushings are broken too. I recently lost my job and i cant afford a repair like this. Could it be a one small thing causing the noise? Thanks for your time.
Apr 20, 2009 at 4:56 AM
BMRFIXIT
  • 19,053 POSTS
Check power steering fluid
rack and pinion don’t make noise
steering would be difficult to steer and or leaking from seals
since you know about the bushing than you should be doing that 1st
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Apr 20, 2009 at 12:39 PM
