1996 Nissan Maxima Power steering
1996 NISSAN MAXIMA
LATINBOY909
  • 15 POSTS
Suspension problem
1996 Nissan Maxima 6 cyl Automatic 185964 miles
a couple weeks ago i had problems with the steering wheel and my mechanic said the power steering pump needed to be replaced. I replaced it but im noticing that a lot of power steering fluid is leaking. Does this mean i have to replace the rack and pinion ASAP or what could the problem be? Thanks
Dec 20, 2009 at 10:20 AM
MATHIASO
  • 1,209 POSTS
Hello –
What you need to do is to raise the car and inspect the rack for leaks at the rubber boot. If there is spurting oil around the boot, the inner rack seal must be replacing.
The rack& pinion should be fine, just the seal will need to be replaced if leak is found there. Check the pressure and return line from the pump to rack for looseness at the rack or a split rubber line causing the leak.
Thank you for visiting 2carpros
Dec 20, 2009 at 11:07 AM
LATINBOY909
  • 15 POSTS
okay, where would the rubber boot be located at? i cant find it on the manual.
Dec 20, 2009 at 11:22 AM
MATHIASO
  • 1,209 POSTS
https://images.2carpros.com/forum/automotive_pictures/46384_power_steering_2.jpg
Raise the car (5 feet up to have better view.) The rubber below boots, the connections lines Are shown in the above picture. Check for power fluid leak at those places. The rack and pinion is not noisy, you just have a leak and the power steering pump is new. Check them and let me know
Dec 20, 2009 at 12:32 PM
