1996 Nissan Maxima Manual Transmission
181,000 MILES • 6 CYL • FWD • MANUAL
PHILWILL
i have a 1996 nissan max manual transmission. accidentally, the car was started i first gear sending the car into a "jolt" after which the car cut off. When I started the car back up, i was able to step on the clutch and put the gear in first, but the car does not move. i also tried putting the car in reverse as well with the same results. The clutch is fairly new. any ideas? thanks.
Sep 6, 2010 at 11:46 AM
  • 75,988 POSTS
Sounds like a clutch problem to me.
Sep 6, 2010 at 7:09 PM
