1996 Nissan Maxima Hesitation when acceleratin
LISADONNELLY
  • 1996 NISSAN MAXIMA
  • 6 CYL
  • FWD
  • MANUAL
  • 215,000 MILES
My car has started hesitating when I accelerate but not when I am driving on the highway.
Friday, July 16th, 2010 AT 11:33 AM
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Friday, July 16th, 2010 AT 8:52 PM
