1996 Nissan Maxima CV Axle Shaft Assembly
1996 NISSAN MAXIMA
140,000 MILES • 6 CYL • FWD • AUTOMATIC
TIMSMITH99
I am planning on replacing both of the CV axle assemblies on my 1996 Maxima and when I go to order the parts, I'm asked the question if I have ABS brakes and if I have a locking differential. How do I know if my car has those features? Also, if anybody has done this how hard will the hub be to break free? I'm thinking this may be the most difficult part of the job.
Oct 14, 2010 at 4:36 AM
WRENCHTECH
  • 20,761 POSTS
You can determine ABS by looking under the car and look for a wired going to the back of the rotor area. Don't mistake the brake line for a wire.
To determine if you have a limited slip differential, block the rear wheels, and get both front wheels off the ground.
Grab one wheel and turn it while watching the other wheel. If they turn in opposite directions, you DO NOT have limited slip. If it will not turn, you do have it
Oct 14, 2010 at 5:10 AM
TIMSMITH99
Thanks. The CJ half shafts were replaced without a hitch.
Nov 1, 2010 at 12:17 AM
WRENCHTECH
  • 20,761 POSTS
Your welcome,
Positive feedback is always appreciated.
Nov 1, 2010 at 12:20 AM
