1996 Nissan Maxima Changing of engines
1996 NISSAN MAXIMA
101,234 MILES • 6 CYL • FWD • MANUAL
GGILL123
Can i use an engine out of a 1994 nissan maxima and put it in my 96 maxima will it work?
Mar 1, 2010 at 8:39 AM
LEGITIMATE007
  • 5,121 POSTS
as long as its the same engine
Mar 1, 2010 at 9:47 AM
GGILL123
the 94 comes wit a single over head cam but a 96 comes wit a double over head cam and the harness and so forth is suppose to be different and the computer box doesnt work with those engines due to the fact thats the engine in the 96 is an upgrade to those in the lower year or am i wrong???
Mar 2, 2010 at 1:09 AM
LEGITIMATE007
  • 5,121 POSTS
not sure, let me see if one of the guys can help me on this one
Mar 2, 2010 at 3:38 AM
CARADIODOC
  • 34,381 POSTS
Hi ggill123, Randy here. Here's a copy / paste version of my reply to legitimate007, who was asking on your behalf:
Hi legit, Randy here. Sorry, I'm not a Nissan expert. I can share two stories but they won't help this person.
I put a 1989 Dodge Dynasy 3.0L Mitsubishi engine into my 1988 Grand Caravan. The newer engine didn't use an intake air temperature sensor, so I just let it lay on top of the engine because it IS needed by the older engine computer. Has been fine like that for 15 years.
Had an early '90s Buick front wheel drive at school. Originally had a 1.8L. Someone put in a 2.0L. It overheated and melted. Students wanted to go back to the proper 1.8L. Used engine dropped right in and as I recall, worked with the same engine computer.
While I'm at it, there are some differences in the flex plates on Chrysler engines. The notches picked up by the crankshaft position sensor are different. The correct one must be used for the specific engine computer. I don't know of a way to determine the correct part except to reuse the old one when replacing the engine.
I would send them to a large salvage yard. There is likely to be someone there who will know. The mechanics at a Nissan dealership might know any differences too right off the top of their heads.
caradiodoc
Now, . . . to add to the story, after I sent that reply, it occured to me that I had a former student who bought a Maxima because it needed an engine. He found the proper engine but ran into so many frustrating problems. Rusted and broken bolts, stripped threads, deteriorated wiring harnesses, and when he got it running, it ran very poorly. It took him less than a week to remove the old engine and put the new one in, then he spent the last six weeks of the Engines class trying to fix all the problems and make it run right. He ended up gving up and selling it.
Since you mentioned the camshaft and wiring differences, I can suggest you also need to find out if the fuel pump will develop the proper pressure, the exhaust pipes will match, the transmission will bolt up, radiator and hoses are the same, air intake, etc. I wouldn't say it can't be done, but it will be a lot easier in the long run to just find the correct engine.
caradiodoc
Mar 2, 2010 at 4:20 AM
LEGITIMATE007
  • 5,121 POSTS
thanx, cardiodoc, can you refer to another expert?
Mar 2, 2010 at 4:42 AM
CARADIODOC
  • 34,381 POSTS
Yup. Have to run a fellow out of town to get his truck fixed. Will be gone for a few hours. What would you like me to do?
Mar 2, 2010 at 5:41 AM
LEGITIMATE007
  • 5,121 POSTS
just ask one of the other guys take a look at it
Mar 2, 2010 at 11:40 AM
