If I was told that I need to replace my timing belt and water pump does that mean that the tranny is about to go bad?
Saturday, July 25th, 2009 AT 12:59 AM
MECHANIC
HI there,
The transmission has nothing to do with the timing belt & water pump, the timing belt is replaced periodically and the water pump may be replaced at the same time, but the water pump is not a mandatory replacement, it can be left if there is no signs of coolant leaking.
