1995 Nissan Maxima Whirring noise when clutch is engaged
106,000 MILES • 6 CYL • FWD • MANUAL
BUFFALOCHIP
When clutch is released when idling in neutral (and when engaging gears) a whirring noise is heard. When the clutch pedal is depressed there is no noise. As the car is driven and warms up the noise persists, but a lower level. I can imagine needle bearings disentregating or not getting an oil bath (the tranny is full). The car has a hydraulic clutch which, I've been told, cannot be adjusted.
Any clues?
Thanks a lot.
Feb 23, 2010 at 11:39 AM
  • 31,937 POSTS
Hi there,
This is the clutch thrust bearing, this is a common problem, the transmission must be removed to replace it.
Mark (mhpautos)
Feb 23, 2010 at 11:44 AM
